network problem in s8 plus
(Topic created on: 05-18-2020 01:08 PM)
nk009
Hello guys
Maine abhi jio se airtel mai port kiya hai signal ka problem tha to port kiya but airtel mai bhi 2 bar hi shoe kar rahahi to mere pass pocof1 hai maine usme sim insert kiy to usme full network show kar raha hai to problem kya hoga ?please help me
12 Comments
Not applicable
accha......hota hain aisa Samsung me...network reset karke dekho
nk009
reset kiya fir bhi nahi ho raha
oyemukul
reset kar lo ek bar na sahi ho to service center me check karwa lo.
NitinBansiwal
reset network settings
nk009
network settings reset , sim nikal ke restart kiya lekin nahi ho raha
NitinBansiwal
settings> reset> reset network settings pe jao waha vo reset karo
dual h to konsi sim ki karni h ye option b aayega
restart karne ki jrurat ni h usme
sim nikalne ki b jrurat ni h
cs_member9
Dear Samsung Member,
We understand the inconvenience you have faced. Kindly follow the below mentioned steps to improve the performance of the device related to network:
  1. Check device network mode settings: Settings > Connections > Mobile networks > network mode SIM1 or SIM2 > network mode.
  2. Check network operator settings: Settings > Connections > Mobile networks > Network operators > Select automatically > OK > Registered on network.
Note: We recommend to set device network operators as LTE/3G/2G (auto connect) mode. Check device network in open area. Kindly check your device in a different location/network coverage area.
If the issue still persist, we would request you please contact your network service provider
nk009
done all as same mention but didnt solve problem
Not applicable
ie kaun hain 🤣🤣🤣😮
