Resolved! Solved
incoming calls not showing numbers or contacts
(Topic created on: 03-25-2020 08:53 AM)
MeliG
My S20 Ultra is not showing names of contacts for incoming calls but picks the contact names for outgoing calls. What could be the problem?
Sif_sam01
Hi MeliG
Your Caller Line Identification may need to be activated. Please contact your Network Service provider to activate.
1. From the home screen, swipe either up or down to access apps.
2. Select Phone.
3. Select Tap on the 3 dots on the top right corner.
4. Select Settings.
5. Select Other call settings.
6. Push slider to activate Show caller information.
31 Comments
Sif_sam01
Hi MeliG
2. Select Phone.
4. Select Settings.
mapula
I have tried this method before, but it still refuses to show names of contacts for incoming calls
Members_dazSImA
I actually Switched off Show Caller Information and now it appears to work.
rpampado
Beginner Level 3
Just done that and that does not work for me
brynjones1979
we switched/slid caller id off and on then the phone on and off. it now works💪
brynjones1979
hi we had this problem and slide caller I'd to off as it was on then back on and turned the phone on and off.  it worked after that displaying caller name and number.   we was heading down the route of caller id activate with our provider but it seems fine now.
GalaxyGuruSA
sometimes, especially with myn,it has that issue,just go yo MTN or call them to activate caller line identification
Wara316
my number is hidden please help
Members_8ghYsRi
Hello my Galaxy A31 is not showing numbers on incoming calls,  all incoming calls are written unknown why?
