display punch hole camera issue
(Topic created on: 10-28-2020 08:06 AM)
Dhanush2969
I have white ring kind of light emitting near the front punch hole camera of my galaxy s20 plus.
It is visible too much in dark room with low brightness and in gray or little dark background. Its annoying too much.
I don't know whether its a software issue or display problem. I don't even know whether its normal but irritating too much.
Can anyone help me know whats the issue is?
Its even more brighter than the image attached.
Dhanush2969
Dhanush2969
its visible on almost all apps with dark background
Ye light hai ya camera ka sensor jaisa kuch jo dark mode me visible hai..ss me utna visible nahi hai..ek baar check Kara lo..or once confirm with any S20+ users...
Dhanush2969
ok bro
i dont have anything as such on my s20+
Dhanush2969
even i did not have this from past 2 weeks
it started showing up suddenly from yesterday night.
even did factory data reset and all
but still have this issue
SinhaAnku
bro do you facing this screen leak or display leak problem in you s20 plus??IMG20201030235207_19376.jpg
Dhanush2969
it was camera sensor that had caused display leak i guess.
anyhow got the display replacement
Adnan3211
Did they charged you for that? Can you please share the detail.
may be screen protector issue?
