display punch hole camera issue
(Topic created on: 10-28-2020 08:06 AM)
Dhanush2969
I have white ring kind of light emitting near the front punch hole camera of my galaxy s20 plus.
It is visible too much in dark room with low brightness and in gray or little dark background. Its annoying too much.
I don't know whether its a software issue or display problem. I don't even know whether its normal but irritating too much.
Can anyone help me know whats the issue is?
Its even more brighter than the image attached.
28 Comments
Sanskar
display issue
Dhanush2969
do u think visiting a service center would help?
obously.... it's a new phone you can even get a replacement
If its like blinking dot at the time you make a call, then that's the proximity sensor..
Dhanush2969
its not blinking.
its constantly there all the time when i open any app having gray background.
Then get it checked once..as its coming while opening any apps(then check all settings) or else visit service center..
Dhanush2969
its visible on all the apps with dark mode
If its possible..share SS
Dhanush2969
