sidanashubham
02-02-2017 03:28 PM in
During charging my galaxy s6 edge as soon as it charged to 100% i unplug my phone and what i notice is that it goes to 98% immediately after removing the charger and when my battery is at 16% it suddenly goes down to 3% even when not in use. Does anyone else also facing this problem plzz help
7 Comments
PSG
02-02-2017 03:34 PM in
yeah
technoBoy
02-02-2017 04:24 PM in
same thing happened with my galaxy s6 .... got my battery changed still this happens . I guess its a software issue and needs to be fixed by Samsung in upcoming Nougat Update
manofsteel
02-02-2017 04:36 PM in
yup
Yogie09
02-02-2017 07:06 PM in
Clear cache partition
Power Cycle Ur phone's battery.
To do this follow above steps:
1] Completely drain ur battery...even after its showing 0% but if U boot ur phone after 5 min or later the phone will start...u may find the battery 5% or odd again...repeat untill battery gets completely drained & unable to start the device any further.
2] While in switched off mode charge ur phone completely 100%...don't switch on while charging let it completely charged while switched off.
3] Once phone is charged to 100% disconnect charger & switch on ur phone...if u get less than 100% charge...connect charger again let it again charged to 100%...disconnect charger > Restart phone.
Repeat Step No.3 Untill ur phone shows 100% battery upon restart.
See if it solve ur above mentioned issue.
sidanashubham
02-03-2017 09:22 AM in
i will try
Yogie09
02-02-2017 07:12 PM in
the same issue had happened with me on my Note5 couple of time...I did the same...
Samsung_India_
02-03-2017 01:38 PM in
"Thank you for Joining Samsung community. We would recommend taking some troubleshooting steps to further isolate what you may be experiencing.
Find troubleshooting steps on provided link http://www.samsung.com/in/support/skp/faq/1101689"
