battery issue s7 edge
(Topic created on: 04-27-2018 02:14 AM)
abhit123
After the security patch update of 1 march 2018 my phone battery life has refuced drastically. please release new update as soon as possible with battery issue solved in it.
7 Comments
AAttri
same problem
abhit123
yes samsung should solve the issue as soon as possible
AAttri
#Samsung pls solve this problem
DrQaisar
Same problem here
abhit123
many people are facing this problem ..lets see if samsung does something
admin_
Thank you for being a part of Samsung community. We apologize for the issue you are facing in the device after the update. We would recommend you to follow some troubleshooting steps in order to further isolate what you may be experiencing in your device. Find the troubleshooting steps on the provided link http://www.samsung.com/in/support/skp/faq/1101689. Please let us know what steps you have taken and if you have noticed any changes or improvements as this will help the Community to provide you further troubleshooting steps without repeating any procedure which you may have already followed. Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
imtiya
same battery problem hai.
