Drastic Battery Drain After Updating to One UI 7 - Even After Factory Reset
(Topic created on: 3 weeks ago)
itz_Rakib
After updating my Galaxy S24 Ultra to One UI 7 (Android 15), I’ve been facing serious battery drain issues. On One UI 6.1.1, I consistently got around 8.5 to 10 hours of screen-on time, which was impressive. But since the One UI 7 update, I now barely get 5 hours of SOT, even with only 5% brightness.
Hoping to fix the issue, I performed a full factory reset, but unfortunately, that made no difference at all. At best, I now manage 5 to 6 hours of screen-on time, which forces me to charge the phone up to three times a day — something I never had to do before.
Here’s what I’ve already tried:
Turned off AOD and Edge Panels
Limited background activity
Disabled RAM Plus
Manually set brightness
Wiped cache partition via recovery
Nothing has improved the situation. This level of battery performance is unacceptable for a premium device after a major update.
Please investigate and address this issue. I’ve seen several users facing the same problem post-update. We need proper battery optimization in the next patch.
Device: Galaxy S24 Ultra
One UI Version: 7.0
Android Version: 15
Security Patch Level: April 1, 2025
7 Comments
GauravOberoi
Bro with my #S25ultra with OneUi7 out of the box i get a SOT of 7hrs with no gaming or power hungry apps. This is very disappointing with the latest flagship.
itz_Rakib
They promised 7 years of updates, yet took 6 months just to release the first one. And when One UI 7 finally came after so much anticipation, the battery condition turned out like this! These things are just unacceptable from Samsung. There are still 6 major updates left-how will this phone even handle them? Will it give just 1 hour of screen-on time by then ?
goodthings
goodthings
Your's most welcome to here.
shellback
Beginner Level 4
I am experiencing the same issue. My phone's battery is draining very fast after receiving the UI7 update on my Galaxy S23.
cs_member10
Dear Samsung Member,
As per your concern, you have already done the possible troubleshooting steps and the issue remains unresolved, we request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
abhay55454
I m also serious battery problem after ui 7 upgrade
