Yono SBI registration problem with e sim
(Topic created on: 12-16-2021 08:18 AM)
imshekhars
So I have two sims in my device sim 1 is my secondary and the primary one is in esim 1 slot. Now, after recent update to the yono sbi app I am unable to register from my primary sim that is in esim slot as yono app is not showing any option other than sim 1.
If you have any solutions please help.
PS: I have tries disabling sim 1 from dual sim settings but still it is showing only sim 1 option.
60 Comments
hfdffg
I am also facing the same problem.my bank registered number is in esim place , while registering in yono esim option is not showing..
Any favorable solution?
Sidgautam
Not working on z flip 5
srinielu
No working for z flip 5 , looking for any alternative solution.
MASQ0110
Same problem with my samsung flip5 esim not detecting for account activation I have been ti sbi I have been jio Shop. They just said simply go back to physical Sim then only its accepting. Sbi need seriously some tech support word is moving on and they are still in 3g. Pathetic
Rkpatil9
Yono sbi should be update with esim option other wise its not work
Samsung_Bz0c6bI
download Yono Lite app and try to register again.
Not applicable
I also face same issue in Samsung s22 esim
MARSNZ
Yono lite is working on esim but not yono sbi
Harimulukutla
Uninstall and reinstall app after esim. Follow steps given by Himanish. It works
Technitwit
Faced similar problem with the full SBI YONO app not recognizing my eSim, on my S23 ultra after switch from Physical. The Yono Lite did the trick for me too. Seems SBI Digital cell will update the full Yono app in a month.
