Yono SBI registration problem with e sim
(Topic created on: 12-16-2021 08:18 AM)
imshekhars
So I have two sims in my device sim 1 is my secondary and the primary one is in esim 1 slot. Now, after recent update to the yono sbi app I am unable to register from my primary sim that is in esim slot as yono app is not showing any option other than sim 1.
If you have any solutions please help.
PS: I have tries disabling sim 1 from dual sim settings but still it is showing only sim 1 option.
60 Comments
Saheerpni
Its working.. But the problem is if you take the sim out then yono not working
Members_wTVVAbv
Hi Himanish, your solution worked like a charm, thanks a ton
sher_khan
Sweet trick BTW..
But either they patched it or doesn't work now..
Thinking and steps were correct but still unable to register.
Another way up ur sleeves ?
This method isnt working
buntbingo
Tried. Not working. The esim is sim 2 in my zflip 4. Sent the SBI reg message to same no. With esim and tried yono. It starts allover again with detecting sim 1 only. Pl elaborate the process sir. My email is buntbingo@gmail.com. thnx in advance.
gvi
Thank you very much👍it worked 🙏
jaineshpk
Not working
Aeh_beh
Did not work for me
Sidgautam
Didn't work for me
J33T
Beginner Level 4
Thanks you so much..😇😇
