Worsen battery life and heating issues after updating to one ui 7.
(Topic created on: yesterday)
workingpayload
The day I switched to One ui 7. My battery life got worse and I am facing extreme heating issues even after just using it for some time. I tried clearing cache partition and also tried resetting my device. Nothing worked. Beta 1 has the best battery life, even better than 6.1.1. When I switched to one ui 7 the battery life was good but One day tried switching to vulkan and that was the day I am facing this issue.
6 Comments
Pintu1991
cs_member10
Dear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device Battery drainage issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
2. Check device network fluctuation.
3. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
4. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Turn off auto sync of e-mails, app data etc.
▶ Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Reset the device:
IMPORTANT:
• For this:
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
I tried everything. Nothing seems to fix the issue. I just want this feedback to reach the developer team so that it can be fixed in the next update.
goodthings
goodthings
Your's most welcome to here.
