Wireless charging overnight
(Topic created on: 03-03-2024 11:13 PM)
Àmit
I just bought an s24 and my sister gifted me a wireless charger.
Is it a good idea to keep the phone on charge overnight over the wireless charger ?
Will it in any way affect the battery life or device in long run ?
5 Comments
muhammadmpp
Don't try . phone is go to overheat
Àmit
Using a wireless charger over cable one is a good idea or not ?
99Case
Please don't. Wireless charging produces more heat which will in turn impact your phone in multiple ways.
Àmit
Ahh okayy
But using in daytime fir charging won't affect in any way right??
99Case
Whenever you are charging your phone through wireless process, keep checking the temperature of the phone by touching it's back at regular intervals (initially). If it's warm, it's fine. But if you feel that it's getting hot, avoid charging wirelessly irrespective whether it's day or night.
Usage of wired charging is always recommended.
