Resolved! Solved
Wired or Wireless Earphone?
(Topic created on: 06-10-2023 12:52 PM)
SYxPlayz
The question is should wired earphones good for new devices?
here is a small context: I am S21 FE and it has only Type C port. Both for charging and audio jack.
I don't have wireless charging so i use the port to charge.
I purchases a Type C earphone which sounds awesome but the problem with them as I have to again plug and Unplug.
My worry is that as Charging and audio both have same port. My pluging and unpluging will Cause it to break or loose for the least part with time.
So i am thinking is wireless earphones or neckbands worth it? Before buying i wanna ask this.
As they may should good but their mic quality **bleep** and i talk on earphone alot on calls and They need to charge again and again too.
So what should i choose
a. A wired earphone with chance or damaging port in long time?
b. A wireless earphones with bad audio quality and worry about charging?
Mgmileshg
You can use wireless for talking and wired for listening music.
A type C port has over 4 lakh plug unplug cycles. So, don't worry, just be careful and calm when using the port.
If you can raise the budget and get TWS/Neckband, the losses while playing audio will decrease and give you good sound. But its not possible in low budget. Wired earphones provide better quality sound in budget than wireless. Now you can choose. But if you're into talking too much, buy a wireless and keep it connected. Switch between devices while on call and you can keep both wired and wireless connected👍
11 Comments
Mgmileshg
SYxPlayz
thanks you so much for detail comments 😁
Mgmileshg
If you like it, can you please accept as answer by tapping on the three dots?
piyussh07
Using s21fe5g and i choose a type c connector bundled with realme Earphones > Wireless buds
samfan91
Type c connector is very durable as long as you use original cables/products. Just be gentle when unplugging.
Bluetooth earbuds are convenient/fashionable, but they are e-waste. You may end up throwing them in garbage once the battery dead.
umesh30
Use branded wireless earbuds...
drshadmaan
S21 fe users , please suggest me I wanna buy type c earphone from Samsung Ic050 cost at 999/ or should I buy normal earphones with a 3.5mm to type c connector . What would be more worth . Please tell
SYxPlayz
You can buy a type c earphone other than samsung. I'm using this one and it's sound quality is awesome and it is compatible with s21fe too.
Here it is on amazon https://www.amazon.in/gp/aw/d/B09HH32578?ref=vse_pfo_vdp
I brought it from local market of 580 so its cheap on amazon.
But do look on comments of that product i search and given you the top one so research before buying.20240120_163722_1000020695_1705748845.jpg
drshadmaan
Thank you so much . One more advice . Please tell me I am getting samsungs offical type c earphone at 675 on student discount. So In long run I should prefer Samsung or potronics . Have you ever tried Samsung Wale?
