03-12-2023 06:44 PM in
Galaxy S- Mark as New
03-12-2023 06:51 PM in
03-12-2023 07:14 PM in
03-12-2023 07:15 PM in
Galaxy S1. Restart your device: Sometimes, simply restarting your phone can help resolve connectivity issues. Turn off your phone completely and then turn it back on again after a few seconds.
2. Forget and reconnect to the Wi-Fi network: Go to Settings > Wi-Fi and find the network that you're having trouble connecting to. Tap on the network name and select "Forget." Then, try to reconnect to the network by selecting it again and entering the password if prompted.
3. Disable Wi-Fi 6: Go to Settings > Connections > Wi-Fi > Advanced > Wi-Fi 6 (802.11ax) and toggle the switch off. Then try to reconnect to the Wi-Fi network.
4. Check for software updates: Ensure that your phone's operating system is up to date. Software updates can include fixes for Wi-Fi connectivity issues.
5. Check your router: Make sure your router is turned on and broadcasting the Wi-Fi signal. Try restarting your router and see if it helps.
6. Reset network settings: Go to Settings > General management > Reset > Reset network settings. This will reset all Wi-Fi, Bluetooth, and cellular network settings to their default values. Then, try to reconnect to the Wi-Fi network.
If none of these steps resolve the issue, you may need to contact Samsung support or your internet service provider for further assistance.
If the problem is solved, then please click on 3 dots near my comment and accept it as a solution to help others. Thank you 😊
03-12-2023 11:12 PM in
03-12-2023 11:15 PM in
03-12-2023 11:17 PM in
Galaxy SU can check through website also most of the user are facing samsung is aware of this issue
03-12-2023 11:18 PM in
03-12-2023 11:42 PM in
