Wifi calling problem s24 plus
(Topic created on: 01-04-2025 06:37 PM)
rams24plus
Always have to reset network setting to on the wifi calling.. not connecting automatically on phone.
Got frustrated..
Anyone with same issue or anyone reslove the problem
3 Comments
goodthings
Please reset network setting of both Sim one by one and than reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also restart your's device without any Sim in slots also interchange Sim in slots also turn off power saving mode then go to wifi setting and click on intelligent wifi also reset wifi and Bluetooth settings then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your query, we request that you kindly follow the steps to resolve your issue.
▶ How to enable the Wi-Fi calling feature via settings
Navigate to the app's screen and tap on Settings.
Tap on Connections.
Tap on Wi-Fi Calling.
Turn on Wi-Fi Calling.
The Wi-Fi Calling feature has been turned on.
▶ How to enable the Wi-Fi calling feature via the Notification panel
Swipe down on the home screen to open the notification panel.
Tap on Wi-Fi Calling to enable.
Wi-Fi Calling has been enabled.
▶ How to enable Wi-Fi calling feature via the Phone App
From the home screen tap on Phone.
Tap on Menu.
Tap on Settings.
▶ If Wi-Fi gets disconnected between the call
The call will switch over to VoLTE and there will be a seamless handover. If VoLTE is not switched on, the call will drop.
If the issue persists, then follow the below steps:
▶ Remove the third-party apps: Settings >> Apps >> Select the third-party App >> Uninstall.
▶ Update device software: Settings >> Software update >> Download and install>>Check for software update >> If Software update available>>Download>>Downloading updates>>Install now.
▶ Reset the device:
Note: Kindly create a data backup of your device via the smart switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
Remember the Google password before resetting the device because it is required during the initial setup.
If you do not remember then advise to reset (Forgot password) the Google account.
For this; Open Gmail (https://accounts.google.com/servicelogin)>>Select forgot password>>Select "try another way" like mobile number, security question, etc.>>Select Next>>Enter a new password>>Tap on Next.
▶ How to reset:
Apps>settings> general management>reset (Reset your device to its factory default settings. This will erase all data, including files and downloaded apps.)
