10-03-2024 12:31 AM in
Galaxy S- Mark as New
10-03-2024 03:55 AM in
10-03-2024 09:41 AM (Last edited 10-14-2024 02:46 PM ) in
Galaxy SDear Samsung Member,
● Forget the Network: Settings> Connections> Wi-Fi> Wi-Fi network>Tap and hold the Wi-Fi network that you're having trouble with until the menu allows you to select Forget Network.
● Kindly reset the network settings. Settings> General Management> Reset> Reset Network Setting.
● Switch off your Router (at the wall or with the power button on the router) and wait for 2-3 minutes before switching it on. While you're waiting, press the Power button on your mobile device and select Restart.
● Once the router has been successfully connected to the internet again, try to connect to your network on your mobile device.
● Make sure there is no interference between the router and your mobile device. Concrete walls, fridges, and microwaves can all interrupt the Wi-Fi signal.
● Kindly check and disable the Airplane/Flight Mode on your device.
● Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
10-03-2024 11:05 AM in
