WhatsApp front Camera is not working.
(Topic created on: 03-08-2024 08:03 PM)
KumarXD
I have tried clearing the data, cache, and reinstalled the application. However, the front camera is not working. When checked in different applications, the front camera is fine.
Phone: S24 ultra
KumarXD
My issue is still not resolved :(
I finally figured out what's causing it. It's the built-in video call effects. If you happen to have a background image added to it, remove it. That's what I did, and it solved this issue.
My problem solved check this
And post
KumarXD
Yeah now it's working fine. Thanks 😊👍
prince146
Beginner Level 3
This solution worked for me as well. Thanks
Yuvaraj105
@himanshu Hi, Pls explain clearly. I'm not getting your point
Members_hwOjb7f
All permission allowed. Back camera working but not able to access front camera
cs_member10
Dear Samsung Member,
As per your query, we request you share the log file also share images, and a short video clip by another device or by screen recording of the issue for better understanding. This will help us to further investigate and resolve this issue.
To attach the log file: Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
swapnil7777
Same problem I am also facing for my S22 Ultra
KumarXD
It's the built-in video call effects. If you happen to have a background image added to it, remove it. That's what I did, and it solved this issue. 😊
