Volume going to 0 automatically
(Topic created on: Sunday)
imayur7
Hello,
Recently I noticed my s22 ultra phone's volume automatically decrease to 0.
And this is happening because phone trying to connect my buds2 even though it is in case (not using).
Whenever I'm near to buds2 case it's happening. Does someone know how to solve this ?
Thank you
7 Comments
Mk901
goodthings
goodthings
You're welcome to here.
vinayshah
Probably ear buds are not kept properly and remains on and on connection or pairing mode. Check if the case is properly closed and buds are properly fitted in their pit.
imayur7
That is not the case, buds are properly placed and closed correctly. And phone only trying to connect when I'm near to bud case. and it's fail every time but during this time volume goes down. it's very irritating.
vinayshah
Then keep "searching near by device" off and see if that helps.
cs_member10
Dear Samsung member,
1. Kindly open the Galaxy Wearable App.
2. Tap on about earbuds.
3. Reset earbuds.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the.
Samsung Members Application (Wearable app>Three dots>Settings>Contact Us> Send feedback>Choose Composer> Select error report > select the appropriate issue category> Type your query and send.)
