10-12-2023 01:58 AM (Last edited 10-12-2023 05:40 AM ) in
Galaxy S- Mark as New
10-12-2023 02:49 AM (Last edited 10-12-2023 02:51 AM ) in
Galaxy S3.) Why would I spend my money for 120Hz and I am not able to use 120Hz ? They should fix this 😑
5.) WiFi eats more battery for me ... so I don't use WiFi all the time.
7.) Keeping Battery Saver ON will reduce the performance... 😑. Use this only when battery is needed for longer time like while traveling.
8.) Na ... not necessary... From my experience, new updates bring more issues. Update only when necessary and if there is some new feature of your use.
10.) Na ... keeping some frequently used apps running is good. Like I always keep WhatsApp, Youtoob, Chrome and Gallery on open on RAM. It makes app opening fast and gives less load on CPU.
13.) Simply remove cover when device heats. Even light cover acts as insulator.
10-12-2023 03:01 AM (Last edited 10-12-2023 03:01 AM ) in
10-12-2023 08:20 AM in
10-12-2023 12:03 PM in
10-15-2023 10:31 PM in
10-16-2023 08:50 PM (Last edited 10-16-2023 08:50 PM ) in
Galaxy S.
I don't update so often
10-12-2023 08:02 AM in
10-12-2023 12:06 PM in
10-12-2023 11:40 AM in
Galaxy SHaving said that my exynos version used to heat alot during the first month of use now it's pretty stable when comes to heating, it gets warm sometimes but never heats in normal day to day tasks.
I get an SOT of 6 hours (85 t0 20) when using wifi, and this SOT reduces to 3-4 hours when using 5g.
