S24 Battery Drain and Heating(Exynos)
(Topic created on: 12-20-2024 06:29 PM)
SIDH16
Samsung please optimize your chipsets or stop selling it.After wasting same money as the Snapdragon version, i am getting bad battery and heating uses in basic uses...This is horrible experience that you give to your customers
6 Comments
SubhadipDas94
Absolutely right.
My s24 plus gives me worse backup than a regular s23
viperdeepu
This would started happening after patch update. Same thing for s23 ultra also it does not last a day as well.
Abeshek
I was facing battery drain issue with my S24 & in one ui 6 verison. After beta update, I can see a significant boost in battery performance. So try enrolling for beta.
SIDH16
Is beta stable....any lags?
Abeshek
No bug as of now, I'm using it in my primary device.
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issues by given links.
Galaxy device battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
Galaxy device charging issue: https://www.samsung.com/in/support/mobile-devices/my-galaxy-device-is-not-fast-charging-how-do-i-fix...
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
