USB Problem in s21fe exynos
(Topic created on: 03-19-2024 12:02 AM)
TheWitcher834
I have Samsung s21fe exynos varient. I tried to connect my phone with my laptop to use Usb tetheing. It connect normally but after some time maybe 5-10mins (sometime this time can be more or less) it gets disconnect every time and if i try to reconnect its shows charging only for min or 2 and then disconnect again. Pls share some tips its really irritating. Already tried to switch on usb debugging.
8 Comments
MonK11
It's a bug I am also facing the same issue, the only way to get it working is by restarting the phone.
TheWitcher834
Is your usb tethering working after reseting the device??
MonK11
Yes everything works
TheWitcher834
Thanks then i will reset my phone
MonK11
Dude **bleep** don't reset it, I said RESTART not RESET!
TheWitcher834
🤣😂 I have already reset my phone. BTW it was not working after restarting. But I haven't check yet after reseting the mobile.
MonK11
cs_member10
Dear Samsung Member,
As per your concern, we would request you to kindly perform the following steps:
Kindly check the functionality with a different device or try to charge the device in a different power socket.
1. Check connectivity: Please check whether the charger cable and adapter are fixed well. Remove the charging cable and reconnect with the mobile phone properly.
2. Check charger functionality: If different devices charge with the same charger. It seems your charger is functioning, before getting into the mobile-related troubleshooting, I would like to know whether you are using a Samsung-approved charger.
Note: We recommend our customers use only Samsung-approved chargers, as 3rd party chargers with different output ratings may cause errors in the device.
If the device charges with a different charger: It seems there is an issue with your charger, kindly check the physical condition of your charger for any damage.
3. Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
4. You can reset your device by following the steps from the below link.
If the issue still occurs please visit the service center for a physical device inspection. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
