USB Detected After Removing Samsung Charger
(Topic created on: 09-02-2024 09:28 PM)
thejayant
USB Connection Detect After Removing Charger
Recently, I've noticed that whenever I remove the Samsung charger from my S24, a notification appears repeatedly stating that the USB connector is connected and disconnected. To remove the notification, I have to restart the phone.
Also, when I connect to a power bank, it works fine, not showing notification for a USB connection.
Help me identify what kind of issue this is? I am using a genuine charger and cable to charge my phone.
2 Comments
cs_member10
Dear Samsung Member,
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
You can reset your device by following the steps.
In case the issue still occurs, kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
SAURAVMISRA
May be your usb connection was set to charging only instead of file transfer.
