The device is very slow, with extreme battery drain and heating.
(Topic created on: 04-25-2025 08:35 PM)
NripenGhosh
Following the Android 15 software update, my S24 Ultra device is experiencing significant performance degradation.
10 Comments
noorrratul
Facing the same issues
avd
S25 bhi to bechna hai
NripenGhosh
Abe yr kuch neya to hea vi nehi 25 ultra pe, bekar me socha q lena avi asa hoga to fir update na karte
NripenGhosh
@samsung please roll back my update to android 14
Rupamdas50
Use odin flash
fal786
bhaghwan
Do wipe cache partition
cs_member10
Dear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device Battery drainage issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
2. Check device network fluctuation.
3. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
4. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Turn off auto sync of e-mails, app data etc.
▶ Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
▶ Galaxy device hanging issue: ● Check space availability: Settings > Battery and device Care > Storage.
● Check RAM in your device: Settings > Battery and device Care > Memory.
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Clear cache memory of a particular application: Settings > Apps > pick the app > Storage > Clear Cache.
● Remove third-party applications.
● Remove memory card: Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount.
● Remove third-party accessories.
● Kindly disable Power saving mode( if enable).
● Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
● Reset the device:
IMPORTANT:
• For this:
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
goodthings
It's a major update. Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
