System storage problem.
(Topic created on: 06-08-2023 11:37 AM)
OnkarB
Does any one have a solution to reduce the system storage.
11 Comments
ravinder_79
The storage problem can be resolved by cleaning up trash from the galley . Go into your gallery and click on the three lines in the corner (to the right of the Stories option) the click on trash and click on the three dots and click empty . Hope that this was helpful
OnkarB
Already knew it, but thanks.
OnkarB
I found one solution for this. You can do the following:
Navigate to Settings -> Accounts and Backups-> Restore Data. In this you can see the backup you can simply delete it by clicking 3 dots-> delete backup. It will free up some space. Like if you find this helpful.
umesh30
Go to > file manager > Analyse storage and than delete unwanted files...
Reset phone problem finished☺️
Pridhvi
OnkarB
It is normal in your case. You must do something with your apps.
Pridhvi
Yup it's a lot😂(my mistake)
Pridhvi
Can you post a screenshot like the one i posted?
