System Issue
(Topic created on: 06-18-2026 11:27 PM)
Namanrx
Beginner Level 4
From past 15 days i am facing these issues
1. Home UI isn't responding.
2. System UI isn't responding.
On S21 FE , snapdragon version
I did clear cache method then phone format 2 times. not installed any app but the issue not resolved. never rooted the phone or not installed any app from outside only from playstore or galaxy store.
Anikroyale
If resetting the phone doesn't help, then you should visit a service center and ask them to reinstall the software. From your screenshots, I can see that yours is a S21 FE Snapdragon; and there is no such issue with this device at the moment, coz even I'm using it. Seems like only your phone is affected.
Also, you don't need to hide baseband, kernel and build number. They are the same for all devices of the same model. The only things you need to hide are the serial number and the IMEI.
8 Comments
Anikroyale
Namanrx
Beginner Level 4
Thank you 😊
Anikroyale
You're welcome :)
OMKALEESH
Expert Level 3
Yeah your right
goodthings
Kindly go to service center for check and resolves this issue. If you like please accept it's as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution.
goodthings
You're welcome here.
cs_member10
Dear Samsung Member,
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
Konkangypsy
It's very common across the devices. Basically older devices with newer android versions
