Standby battery drain
(Topic created on: 01-20-2024 02:22 AM)
MrutyunjayAdap
Samsung really needs to improve the one ui optimisation for better standby battery drain in S23 series. Even if the phone is kept idle for some time, the battery drains a lot. Every night the battery reduced by 6-9%.
Overall the battery optimisation needs to be improved for a longer battery backup.
Please Samsung atleast bring down the idle battery drain.
6 Comments
jitender751
Bhai phone charging se htate hi 85 se 84 ho jata h , cable htate hi 😅😅
Exactly bro
AJAB_MORIA
Wait for next update. it will be fixed. 💯
Yeah just hoping for it.
sammy25
It's a special Samsung feature😂, agar ye nahi hoga to pata kaise chalega phone Samsung ka hai😂.
cs_member8
Dear Samsung Member,
As per your query, We want to inform you that the issue could occur due to usage and various other factors, however, it is our best endeavor to provide you with an impeccable product experience at Samsung. We are taking your valuable feedback regarding this. If you are facing the battery drain more than usual then kindly perform the following steps.
Charge in one go instead of charging many times as it affects the life span of the battery and battery performance
Perform Battery Optimization
Settings > Select Device Maintenance/Device Care/Battery and device care > Optimize > Optimize all options like Battery, Storage, and Memory
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast.
Recommendation: We recommend you avoid using it in areas with low network/fluctuation.
Reduce display brightness level
Kindly set the device display brightness in auto mode (If available).
Adjust screen timeout settings: Settings > Display > Screen timeout > Select minimum screen timeout.
Check and update the App: Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Close background running apps
Close all the background running apps when not using them,
Turn off auto sync of e-mails, app data, etc.
We request you turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
The steps to turn off auto sync are:
2. Turn off the auto sync option.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
