Solution for S24 Ultra Yellow tint
(Topic created on: 01-26-2024 05:49 PM)
ShahabJ
The display of the screen is very anti reflective which makes it seems quite dull. I noticed disabling these options helped:
Adaptive Color Tone
Disable Adaptive Color Tone:
Settings > Display > Adaptive Color Tone {Disable}
This will take care of the Yellow tint on the display.
Next ,
Settings > Wallpapers & Style > Dim wallpaper when Dark mode is on {Disable}
Also see if disabling Eye Comfort Shield under display seems okay (I keep it on, but disabling it makes the screen bright)
Another option is Extra Dim under Settings > Accessibility. Enable it according to your preference (I had it enabled in S23U but S24U doesn't need this).
5 Comments
cs_member10
Dear Samsung Member,
Thank you for sharing your feedback. , if you have any further queries kindly feel free to get in touch with us.
rk1287
This isn't helping
rk1287
This is a issue. Samsung should fix it ASAP
macs24ultra
I'm also facing yellow tint screen issue for s24 ultra
Ronqk
I have a yellow dot on my s24 ultra screen.Its in middle
