Serious Problem: Auto Processing of Images taken with S23U
(Topic created on: 04-12-2023 12:54 AM)
SouvikPupun
how to turn off auto refining of images immediately after clicking? It ruins the actual picture by adding artificial contrast and is so annoying. Note: Already turned off auto HDR & scene optimizer but to no avail..
#S23Ultra #Samsung
4 Comments
S_Kumar73
Try to turn off scene optimizer and then check.
piyussh07
Shoot in raw then😄
Because there's a significant difference if you modify *what you mentioned in *Notes*
Download Camera Assistant from galaxy store, and turn off auto HDR
Sayam_Hossain
Bro, I am having the same issue. specially in portrait mode. It is running the skin tone with red tint and making it saturated.
Is your problem solved bro ?
