05-28-2025 04:46 PM in
Galaxy S- Mark as New
05-28-2025 05:03 PM (Last edited 05-28-2025 05:04 PM ) in
Galaxy SAdvice: Don't use other brand's or local chargers to charge your Samsung phone.
05-28-2025 05:06 PM in
Galaxy S1. Loose or faulty charging cable or adapter – Try using a different cable/charger to see if it stops.
2. Dust or debris in the charging port – Carefully clean the port with a soft brush or compressed air (don’t use sharp objects).
3. Charging port sensitivity – If the port is slightly damaged or loose, it can connect/disconnect frequently, triggering repeated notifications.
4. Software glitch – Try restarting the phone. If that doesn’t help, you might consider wiping cache from recovery mode or checking for a software update.
If it continues, you might want to run a diagnostics check via the Samsung Members app > Support > Phone diagnostics > Cable charging.
Hope this helps! Let me know if it improves.
05-28-2025 05:18 PM in
05-28-2025 05:37 PM (Last edited 05-28-2025 05:38 PM ) in
05-28-2025 05:28 PM in
Galaxy SHere's what you can do:
1. Locate Your Invoice: Ensure you have the purchase invoice handy, as it's required for warranty claims.
2. Visit a Samsung Authorized Service Center: Take the charger, along with the invoice, to a nearby Samsung Authorized Service Center. You can find the nearest center here: Samsung Service Center Locator.
3. Explain the Issue: Inform them about the charging problem you're experiencing. Since the charger works with other devices but not with your Galaxy S25 Ultra, this information will be helpful.
4. Warranty Claim: The service center will assess the charger. If it's found to be defective, they should offer a replacement under warranty.
If you need assistance locating the nearest service center or have any other questions, feel free to ask!
a month ago in
Galaxy SDear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
