Screen red tint issue not resolved
(Topic created on: 04-30-2017 02:32 PM)
Wguy
bought the recently s8 fairly early and was unlucky to find out my device was one among the defected display. Unlike a red tint in the entire screen, mine had only redness gradient towards the bottom of the screen. i recieved the latest update today (30 Apr) and the issue seems to have worsened with red being more prominent gradient than before. kindly aadvice if i have to replace the device despite the update did not work.
6 Comments
AbuTurabK
Same here. I have red on right and left sides. Update didn't work.
tony5
have you tried changing the tint in the settings?
check on you tube i saw some solutions for this problem
Hassaman
go into your display settings and try adjusting the tint colour
lone121
I am facing the same issue. done with all the settings and troubleshoot. red tint on right side is affecting my Vision.
lone121
need solution
