Screen Problem
(Topic created on: 07-10-2023 08:38 PM)
SHUBHS20
Facing flickering issue, screen change into white
4 Comments
umesh30
Restart the phone. If not working than do Factory reset (before do that backup your data). If not working at all than go to Samsung authorised service center.
SHUBHS20
Facing isse after update,
Went to samsung authorised centre, they said panel will have to be open, display will have to be checked, talk like stupid.
cs_member10
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. Please follow the easy troubleshooting steps which might help to solve the issue.
Step1: Navigate to the app's screen and tap on Settings.
Step2: Tap on Display.
Step3: Adjust the brightness.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Thank you for writing to us.
Samsung Customer Support.
YolandaPV
Beginner Level 4
I'm having the same issue since last update, like a week ago or so. Screen flickering and a white overlay than comes and go for no apparent reason. Tried disabling auto-brightness, restart phone, wipe cache partition ,to no avail. It's like a software glitch introduced with said update.
Hope they give a solution soon, it is so annoying.
