Samsung s23 fe photo noises and battery drain problem solved next update please
(Topic created on: 4 weeks ago)
rajeshkumar77
Problem solved request
3 Comments
Fedron
Samsung will solve that soon! 🚀
Be ready
rajeshkumar77
Yes
cs_member10
Dear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
1. Galaxy device camera issue: ● Kindly check the physical condition of your camera lens.
● Use a microfiber cloth or a cleaning wipe to clean the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
2. Galaxy device Battery drainage issue:
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
