Samsung s22 charging port issue
(Topic created on: 04-20-2025 07:08 PM)
groot2113
It shows moisture / foreign material found in charging port or cable but both cable and port were clean nd clear
# help me with issue
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issues by using given link.
● Galaxy device moisture issue: https://www.samsung.com/in/support/mobile-devices/moisture-handling-tips-for-mobile-phones/
In case the issue persists, please take your device to the nearest service centre for a physical inspection. You can locate your nearest service centre by visiting https://www.samsung.com/in/support/service-center/.
