Samsung s21fe circle search problem
(Topic created on: 10-08-2024 10:42 AM)
michaeljazz
3 Comments
Enable the google app and android web
michaeljazz
How
cs_member10
Dear Samsung Member,
How to set up Circle to Search feature:-
Step 1. Open Settings > Tap Display.
Step 2. Tap Navigation bar.
Step 3. Enable Circle to Search to On.
How to use Circle to Search feature:-
Step 1. Tap and hold the home key.
Step 2. Use your finger or an S-pen to circle or tap the object of interest.
Step 3. Once your finger or S-pen is removed from the phone's screen, the web search will begin.
Note: Due to the nature of the search algorithm, searching for the same image may produce different outcomes.
If still unable to use, it can happes due to Google Policy, underage Google Account users cannot use Google's Discover and Generative Wallpaper features on the Galaxy device. Restricted access to the use of Google's Discover and Generative Wallpaper features on Galaxy device for underage Google Account users
Notes: ●The above is subject to change dependent on Google policy updates.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appriopriate issue category> Type your query and send.)
