Samsung s20fe 5g.. now volte option not showing... now problem please update πŸ™„
(Topic created on: 06-15-2022 09:45 PM)
beardbharathi
Volte not working..
8 Comments
RajeshKakarla
It is showing in my S20 FE 5G mobileScreenshot_20220615-222936_Samsung Members.jpg
beardbharathi
What network sim used
S_Kumar73
Open Quick star from Goodlock app and then open visibility of indicator icons and then check whether you turned off the IMS Network icons. If yes then turned on.Screenshot_20220616-045458_QuickStar_64609_1655335498.jpg
S_Kumar73
You can accept the solution if your query is resolved
DiveshM
Hi what app is goodlock? I can't find it
fahadaslam
Yeah. They removed the VoLTE enable disable option in April update. And I'm too facing issues with VoLTE and VoWiFi ever since. If you're mobile network in your area is fine, turn off WiFi Calling. Then VoLTE will work fine because the phone is not switching automatically between both network modes. Screenshot_20220616-081227_Call settings.png
cs_member8
Dear Samsung Member,
We acknowledge your query and apologize for the same. To resolve your device network issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
