Samsung s20 series display problem
(Topic created on: 10-03-2022 05:26 PM)
jaykumaran
There like lines running all way from top to bottom in s20 ultra.And temporary fix i dont know it works but i'm just sharing my display settings so that it helps anyone out there.
3 Comments
iamrohitkm
I can't see any lines.
jaykumaran
How will the screenshot show lines even if your display is carcked the screenshot shows non invasive image ...if took video from other mobile, lines it would be quite visible..
cs_member8
Dear Samsung Member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
