Samsung s20 fe 5g battery drain issue pls any settings
(Topic created on: 10-28-2023 09:31 AM)
Lepakshi
Samsung Galaxy s20 fe 5g battery issues
2 Comments
CodingNET
Dear User,
We download applications from Play Store or from any other internet source [in form of .apk]. Some of these apps requests us to turn off battery optimisation for them. To solve this issue there is two methods. Both of them are useful if you do both of them it's good.
Method 1-
•Open Settings and Go to Apps settings.
•On the top right corner, there is three dots. Click on them. Three options will appear. Click on "Special Access" option. A bunch of options will appear.
•Then click on 'Do not distrub permission'.
•Turn off switches for every apps except - Android Auto, Google Play Services, Shell.
METHOD 2-
•On settings locate 'Battery and Device Care'.
•Click on battery.
•First go to Background Usage Limits.
•Turn on 'Put unused apps to sleep'.
•Then go to 'Never Sleeping apps'. Turn off all switches.
•Then come back to battery and go to 'More Battery Settings'
•Turn on all the switches you can see.
Still problem not solved? Then it's time to change battery of your Galaxy S20 FE 5G. Chinese batteries are also the reason for this problemm
Thank you,
Dhanyawad 🙏
cs_member10
Dear Samsung Member,
Charge in one go instead of charging many times as it affects the life span of the battery and battery performance
Perform Battery Optimization
Settings > Select Device Maintenance/Device Care/Battery and device care > Optimize > Optimize all options like Battery, Storage, and Memory
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast.
Recommendation: We recommend you avoid using it in areas with low network/fluctuation.
Reduce display brightness level
Kindly set the device display brightness in auto mode (If available).
Adjust screen timeout settings: Settings > Display > Screen timeout > Select minimum screen timeout.
Check and update the App: Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Close background running apps
Close all the background running apps when not using them,
Turn off auto sync of e-mails, app data, etc.
We request you turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
The steps to turn off auto sync are:
2. Turn off the auto sync option.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
