Samsung please fix heating issue in Samsung s22 with one ui 8 update
(Topic created on: 07-01-2025 07:37 PM)
tanaychoubey
Please fix it
5 Comments
BiRdMaN
It is a BUG send an error report along with log files to customer support through this members app and Samsung will fix it in the next update. To do that follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful please Accept it as a solution Thank you 😊
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concern. We are taking your feedback regarding this matter and will take it into consideration for future updates.
1. Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Checking for software update > Software update available > Tap on Download > Downloading updates > Tap on Install now.
8. If the issue is still not been resolved, Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
tanaychoubey
I done all these steps
