Samsung galaxy S22 ultra one ui 7 update problem solution please
(Topic created on: 05-12-2025 02:03 AM)
shanisingh5838
Samsung galaxy S22 ultra one ui 7 update problem solution please.....?
1 battery drain problem
2 heating problem
3 hang problem????...please solve😮💨🥹😭🙏
One ui 6.1 update not problem no battery drain no heating problem and no hang😭🙏😮💨🥹.....????
1.I'm not use always on display...?
2 I'm use battery protection 85....?
3 power saving use ....?
4 I'm use deep sleeping apps...?
5 motion smoothness standard 60 hz ..?
6 Adaptive brightness no use Extre brightness no use .....?
.....but battery drain problem....???
......I'm sharing 5 pics......????
......please solve ...........????? 🙏 🙏 please solve 🙏 😢 😔........
I'm use off high settings off all....but battery drain no solve.......😭🥹😢🙏😭
13 Comments
Bhai roj 10. 20 percent lowe h* jati hai jaldi
cs_member10
Dear Samsung Member,
As you are facing multiple issues with your device, we kindly ask you to share the log file with us. Additionally, if you have any video clips or images that illustrate the problem, it would greatly enhance our understanding.
Path: Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
goodthings
goodthings
Your's most welcome to here.
