Samsung S25 Battery drain
(Topic created on: 02-22-2025 04:41 PM)
MaheshMahi4444
Samsung S25's battery is getting drained 10 plus percentage overnight in idle time.
8 Comments
Kunapatra
Use Dark Mode and Avoid Always on Display in Night
Thank you, I have my dark mode on and no always on display. Infact don't use 5G I am connecting to home wifi network. Still the issue persist don't know why. Is it because of the ONEUI 7 update recently.
Kunapatra
May be but check ur settings
Kunapatra
My phone is S23 and I use this settings and my phone work fine1740223273014.jpg1740223273031.jpg
Thank you😊
Kunapatra
U r welcome 😊🙏
iamrohitkm
My s23 ultra drains hardly 2 to 3% overnight in idle time and sometimes it won't drain also.
cs_member8
Dear Samsung Member,
As per your concern, we want to inform you that when initially using the device, battery consumption may be rapid due to learning battery usage patterns and application of performance optimization. It will stabilize after a certain period, but if still facing issues, kindly perform the following steps to resolve your issue.
● Galaxy device Battery drain issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
9. Update software (if available): Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select """"try another way"""" > Next > Enter a new password > Next
If the issue still persists than we request that you share the log file from your device within 15 minutes of the occurrence of the issue. You can do this by using the error report option available in the Samsung Members application.
Additionally, if possible, please include a video or screenshot demonstrating the issue. Here are the steps to share the log file:
To share a log file, (Open Samsung member application >> Tap on support >> Tap on send feedback >> Choose composer option >> Select error >> Select the appropriate category >> Type your query)
