S25 battery drain Issue.
(Topic created on: 02-22-2025 06:28 PM)
anuragreddy
S25 phone's battery is draining about 10 percent oveover night. @Samsung care please solve this issue
6 Comments
Kunapatra
Change ur phone battery setting to this I think this will fix 1740229292361.jpg1740229292379.jpg
anuragreddy
Using same and enabled dark mode in the night
Kunapatra
Ok then wait for one day the phone will analysis ur usage and then it will fix ur problem
anuragreddy
Brother I have been using this setting since the time of purchase.
Kunapatra
Ok then wait for the next security patch maybe that will fix
cs_member8
Dear Samsung Member,
As per your concern, we want to inform you that when initially using the device, battery consumption may be rapid due to learning battery usage patterns and application of performance optimization. It will stabilize after a certain period, but if still facing issues, kindly perform the following steps to resolve your issue.
● Galaxy device Battery drain issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
9. Update software (if available): Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select """"try another way"""" > Next > Enter a new password > Next
If the issue still persists than we request that you share the log file from your device within 15 minutes of the occurrence of the issue. You can do this by using the error report option available in the Samsung Members application.
Additionally, if possible, please include a video or screenshot demonstrating the issue. Here are the steps to share the log file:
To share a log file, (Open Samsung member application >> Tap on support >> Tap on send feedback >> Choose composer option >> Select error >> Select the appropriate category >> Type your query)
