Samsung S24 Ultra Sunlight Display Issue
(Topic created on: 3 weeks ago)
RAMULTRA24
Hi,
I am using Samsung S24 Ultra and Unable to use even 10 minutes in Sunlight...
After using mobile for 3 minutes or so the Screen is getting Over heated & Unable to see the Display as it will become Dim after that it will become Normal only after you go it Indoor..
I am facing this issue since many days tried lot of Solutions suggested by Samsung team in Samsung Community forums like Reset, applying adaptive Color tone,.....etc., but this problem was not fixed
Finally last week I visited Samsung Service Center, they tried :
1.IQC---No Problem in it,
2.They Done Software for it---Unable to fix the issue
I was really vexed of trying all these and not getting any solution for the above Problem..
it's Big Issue in a Flagship Mobile But Samsung was Unable to fix the issue
Buying Mobile for Lakhs of rupees But Unable to Use it even 10 Minutes in Sunlight Displayyyy
So Dissappointed for Purchasing Samsung S24 Ultra with above issue..
I wasted lot of Money, Lot of time, lot of Efforts......etc.,
What to do now ????
See the Below Video
3 Comments
Haridhvar23
Turn off dark mode And try
cs_member10
Dear Samsung Member,
As per your query, we request you to share the log file. This will help us to further investigate and resolve this issue. Please also share the photos or videos regarding your concern.
To attach the log file: Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
RAMULTRA24
We are effected persons not your R&D...
I Purchased this mobile with Lakhs of Rupees and Unable to use in Sunlight for 10 minutes also...
Even 10k Mobile can be used in Sunlight as Good for long time...
While i am riding on bike I am unable to Navigate on maps in mobile due to Display issue
Fix the Issue or Recall the Mobiles
Sooo Dissappointed
All Mobiles of Apple, Redmile, Readme, Poco are excellently working in Sunlight
SAMSUNG Should be Ashamed of this👎👎👎
