a month ago in
Galaxy S- Mark as New
a month ago in
a month ago in
Galaxy SDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
![](/skins/images/E96231B01B29FDD93C89D8EA49BE7116/responsive_peak/images/icon_anonymous_message.png)
