Samsung S22 Battery Drain
(Topic created on: 06-22-2023 10:35 AM)
punzzzzzzz
I just gifted my mom a Galaxy S22 on 15th June. When she started using it the day after with a full charge in the morning, by the evening it almost lost its charge bringing it to less than 20%, with just your minimum use of the phone.
No games, just calls and surfing the web and social media. After this, we went to the Samsung's 'registered' service center. There they kept the device with them for a day. When we came back the other day, they had shown us their so called 'test' on a piece of paper in which they had measured the battery usage and clocking down the times. And according to them it is just a normal drain. But the phone's battery is draining faster than usual phones. Today it's been 4 days since the phone is lying at the service center.
Please let us know the solution.
Thanks.
10 Comments
swapan1997
If you got 4 hours sot from your s22 then it's ok ...bcz of this small battery
punzzzzzzz
okay will check what's the sot, I think it was close to 3hrs that day
DrRajanThakur
S22 series has battery problem due to processor.
swapan1997
No ..i got 7 to 7.5 sot from my s22 ultra ....
SRIMAN7382
Bro S22 avg battery that company claims is 6 hr like that but battery conditions will be based on your surroundings too and even frequent charging can decrease your battery health.
punzzzzzzz
that's what we can't frequently charge a device daily, what's the meaning of buying a 60k device then
SRIMAN7382
You can go for s22 plus right you would get some better battery.
punzzzzzzz
But S22 was the ideal compact phone that's why chose that, and it was in budget so
SRIMAN7382
No problem it's a best phone only battery is issue we will see it might be fixed in future update
