S24 Ultra battery drain issue after OneUI 7.0
(Topic created on: 05-18-2025 03:05 AM)
AbhinandMishra
Ever since OneUI 7.0 update on my S24 Ultra, I'm facing fast battery drain on -
1. Idle/Stand-by
2. Video calls
3. General moderate usage
Samsung support team, please look into this matter!
4 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
