Samsung S21 fe net problem
(Topic created on: 05-20-2023 03:06 PM)
Balajohn
My Samsung s21 fe network connection very slow
14 Comments
hdoniv
network connection has nothing to do with mobile. it's with SIM card.
1. Try removing the outer case, to check the reception
2. Do not expose ur fone to excessive moisture..
3. Try moving to other locations
4. if nothing works, call up customer support. he has a way to tell ur signal strength of location..
cheers, happy weekend
Prashanth_P
Who told you brother? Mobile & software too place a role in signal reception.
hdoniv
it sure does buddy. but the primary cause is important to ensure, that physical location is not the problem.
Prashanth_P
Yes buddy 🙌
dabumukesh
5G sahi nahi chal raha baar baar jio ka network 5G se 4G me drop ho raha hai or airtel me to chal hi nahi raha
Same issue he bhai and phone gets very hot
dabumukesh
Han cahe to omlet bana lo phone ke upar😀
Bhai lekin Mai to veg hu 😥
dabumukesh
Hu to me bhi veg par ek dukan kholnge bina silender ke hi omlet bana bana ke bechenge to khuch kama hi lenge kam se kam phone ki keemat to niklegi 1 saal me.🤣🤣😂
