04-24-2022 10:11 PM in
Galaxy S- Mark as New
04-24-2022 10:24 PM (Last edited 04-24-2022 10:25 PM ) in
Galaxy Su can read more here.
https://r2.community.samsung.com/t5/Tech-Talk/autorestart-issue-in-samsung-phones/td-p/11059145
04-24-2022 11:23 PM in
Galaxy SLekin exynos 850 me motherboard issue. Rare case hai.
04-24-2022 11:31 PM in
04-24-2022 11:39 PM in
Galaxy SPichle wale post pe f12 me ek baar auto restart issue tha to mujhe laga ki vo bas ek baar hi hua hai to maine vaha par bola.
Lekin phir m12 me iss post me bola hai ki auto restart issue hai to mujhe laga ki sayad mai galat bhi ho sakta hu, isliye comment kiya.
Sorry agar tumhe kuch galat laga ho to aage se dhyan rakhunga😬.
04-25-2022 06:50 AM (Last edited 04-25-2022 06:52 AM ) in
Galaxy Smaine to esa kuch bhi ni kaha ki mujhe boora lga..🤭
04-25-2022 08:57 AM in
Galaxy SYou can try the following setting to fix this problem...
(There is no 100% proof)
Go to Settings > Battery and device care > three dots menu > Settings >
Turn off "Auto Restart at set times"
Hope it might be useful 🙂
05-19-2022 10:40 AM in
Galaxy SDear Samsung member,
Kindly use a genuine Samsung charger.
Note: We always recommend using a genuine Samsung charger for charging your device.
There are two methods to disable the auto-restart function
Method 1
Please follow the below steps:
Step1: Navigate to the app's screen and tap on Settings.
Step2: Tap on General management.
Step3: Tap on Reset.
Step4: Disable Auto restart (if enabled).
Step5: Auto-restart disabled.
Step1: Go to "Settings"
Step2: Tap on "Battery and device care"
Step3: Tap on Three dots
Step4: Tap on "Automation"
Step5: Disable "Auto-restart at set times" if enabled
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback >Error report).
Warm regard,
