09-18-2025 04:58 PM in
Galaxy S- Mark as New
09-18-2025 05:27 PM in
09-18-2025 05:28 PM in
09-18-2025 08:21 PM in
09-19-2025 08:59 AM in
Galaxy SDear Samsung Member,
At Samsung, we always aim to provide impeccable services to our customers, and we highly regret that you feel this way.
Please follow these easy troubleshooting steps which may help in resolving this issue.
● Kindly use a genuine Samsung charger.
● We always recommend using a genuine Samsung charger for charging your device.
● There are two methods to disable the auto restart function.
1- Tap on Settings> General management>Reset > Disable Auto restart (if enabled)> Auto restart disabled.
2- Tap on Settings> Battery and device care> Three dots> Automation> Auto restart at set times if enabled.
● If you are facing this issue after installing any new application then uninstall that application.
Tap on Settings> Apps > desired app> Uninstall> Ok.
● Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
● Reset settings: Tap on Settings>General Management> Reset and then tap on Reset settings.
