S7 edge mic not working when using earphones
(Topic created on: 07-15-2017 12:35 AM)
MrSagar
Hi,
This is an issue that I have been facing since months now. Whenever I call someone and if I am using earphones, the other person is unable to hear my voice. I can hear him/her correctly.
I have checked with many different earphones too including Samsung's in box one's. They aren't working for me but they are working for other devices.
So earphones are fine.
I'm not facing this issue if I'm removing my earphones and I'm able to talk normally.
Mic is fine.
Can anyone suggest what else can I do/check?
Thanks.
2 Comments
admin_
Thanks for being with Samsung and for sharing your concern. Let me recommend some steps to further isolate and determine what you are experiencing. Please be aware that device speeds may vary based on multiple outside factors. It appears that there may be a third party app or other program that may be leading to what you are experiencing. Placing your device in safe mode disables all third party apps upon startup, to help determine if the use of a third party app is interfering with your device .restart your phone in safe mode. While your phone is powered off, press the power button to turn on the phone, once you see the Samsung logo appear press the volume down key and hold it until you have completely booted up. Also, the relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
mamta12
iam also facing bt in starmaker app my earphone mic is not working
