S7 edge fingerprint scanner
(Topic created on: 07-12-2019 10:34 AM)
Gluckñt
Beginner Level 3
Error showing on trying to add Fingerprint after Resetting my S7 edge?
How to fix this softwarw issue
4 Comments
riju
reset ir and try again
xdgone
open settings and then move to app , click option show system apps , select finger print than click clear cache and data . restart the device and try to set fingerprint
Gluckñt
Beginner Level 3
nothing happend.
I think its a software fault
xdgone
dial *#0*# and select sensor and than from fingerprint click normal scan .. post the result now
