S7 battery usage after may update
(Topic created on: 05-23-2017 08:23 AM)
ashishsingh
My galaxy s7 is running absolutely fine with may update. 13.26 hours with 40% battery left.
5 Comments
PratikD
Battery life is pathetic after may update. Wonder when samsung will learn to make rom
pratap
Same problem....
Not applicable
Bro that 13 hr 25 mins is not Screen on time and is not a good indicator of battery performance
that number shows time since you last charged your phone, so if suppose someone has charged his phone to 100% at 12 night and then went to sleep, wake up at 8 am with 97% battery, it will show 8 hour with 97% left
best measure is screen on time which shows amount of time screen was on,and used
adityabhaskar
look for my post - amazing battery life on s7 edge
if you want to know what kind of stats I'm getting .
admin_
Thanks for sharing your experience with Samsung member. Keep posting!!!
